I'm working on my Midget clutch. The thing will not go in to gear.(Grinds on all gears when the clutch is depressed) /ubbthreads/images/graemlins/driving.gif I checked the clutch travel and have maybe 3/4 inch. Is that enough? I can manipulate the clutch pedal from under the hood and watch the slave cylinder travel. Is the slave cylinder supposed to move over an inch? Also, should I disconnect the slave cylinder from the transmission while bleeding the slave? How do you get to that darn thing? I may be too old for this.
