How many of you have or had an Austin A40 Somerset
JPSmit
Not a lot of them around these boards, so, please, stay and keep us posted. I am not actually aware of any - but there are a couple of A30's. That said, I don't know if you have come across Joe Lightfoot in Picton ON? He has a bunch of (mostly too far gone to restore) cars in his backyard and, I believe has a number of A40's if you need parts.
JPSmit
These little cars seem to be as rare as hen's teeth!!!
They are, partly rust, partly the fact that they were never remarkable (or worth preserving back in the day) and, now it costs far more to restore than they will ever be worth. I know a few years ago there was a Somerset Convertible (I think even for sale) at British Car Day at Bronte. I remember someone commenting that it would be lovely restored if someone didn't mind that there would never be appropriate return on investment.
BTW - you have maybe seen this picture - dumping NEW A40's at sea - from Victoria.
https://www.flickr.com/photos/45379817@N08/7273474918/
Sherlock
I know that if you were to poll across Canada (and the United States) simply through the various networks of the British Saloon Car Club of Canada, you would find quite a few around still, you aren't as alone as you think you are...
JPSmit
I've just applied to the British Car Club of Canada and am waiting on my membership approval.
I am a member, and I still think they are thin on the ground, which makes them even more interesting in my eyes.
whitebuffalo
I'm envious of yours, as you have the floor shift and a great grill! However mine does have a running engine.
I am not sure where the transmission came from. While cleaning it up to see what I have to do I noticed that the floor was roughly cut around the transmission so it is a transplant from something else. It seems to be a three speed so not sure what it is from. I have a four speed from an MGB so will put that in and fix the floor appropriately. I plan on adding an 1800 to it as well. :encouragement:
aeronca65t
In 1966, when I was about 15 years old, I bought one for $20 and used it for a "woods car" to drive around (illegally) in the South Jersey Pine Barrens. Long gone, but great memories. The A40 engine burned a lot of oil. I was always begging for used oil from my Dad or neighbors (after they did an oil change). The car never got actual "new" oil. One time, we couldn't find any oil so I went searching in my father's shed. I found "oil-based" paint. I figured, "What the heck....better than nothing!". The exhaust smelled awful for quite a while after that. Eventually, the engine spit a rod and piston out. I pulled the pan and cleaned it out as best as I could. Then I re-sealed the oil pan with sheet metal, canvas, self-tap screws, caulk and probably whatever. I disconnected the valves on the dead cylinder. After that, it was a "triple" instead of a "four". It leaked more than ever, so I would put an old bucket under it to catch the dripping oil.....and then pour it back in. I still have the rod that escaped from that engine. It's a paper-weight on my desk. Here's pictures of it from back in the day:
B
Not a bad looking A40 Devon ;)
rvm
Currently have two, a four dour sedan and a coupe. Both in need of a lot of work. The sedan is sacrificing itself for the coupe.53austfrt.jpg
Both engines were seized so looking for options.
Cheers
Ross
Calgary
B
@RVM you might try some ATF mixed with Acetone 50/50 dumped down the spark plug holes and leave it for a few days and then trying a bar to work the crank back and forth a little at a time. I've saved engines in the past this way. After I get my 3rd here I can see if I have 2 engines that will rotate (I have 1 now)If so I will probably let one go as I intend to restore one, rod one and use the third for parts.
aeronca65t Austin A40-mine many years ago Other British Cars 1
A TR6 How many fuel filters-TR6 Triumph 25
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
ahealey1004 For Sale MGB OD transmission, many parts in Phoenix,AZ MG Classifieds 4
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
M TR2/3/3A How many miles to seat piston rings? Triumph 4
M Fat Feet hitting too many pedals Austin Healey 23
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
Y MGB First of probably many questions - driveshaft transplanting: MG 3
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
NutmegCT So many cars! So much has changed! Other Cars 10
Tr3aguy General TR So many parts Triumph 7
AngliaGT Many Minis Spotted 5
Sarastro TR4/4A TR4 saga continues: why does Craigslist attract so many flakes? Triumph 16
T How many hours to reassemble a BE? Spridgets 16
Rut MGB Too many cars MG 31
M How Many McLaren owners are here? Other Cars 6
K Spitfire '78 cuts out after many miles of driving Triumph 8
S This is why I spend so many nights in the garage... Spridgets 7
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
HealeyRick How Many Big Healey Guys are Spridget Guys? Austin Healey 23
J E brake help forgo many Big Healey owners Austin Healey 8
luke44 TR2/3/3A TR3 Door Panel Screws - Location - How Many and Where? Triumph 10
MikeAH100M How Many BN2 Overdrive Relays?? Austin Healey 2
J How many people retain their original generator? Spridgets 16
Frank C. How many Healeys are still on the road? Austin Healey 10
B TR6 Removal of TR6 crankshaft end bolt! MANY THANKS! Triumph 3
af3683 SU Carbs - How many flats? Triumph 3
JamesWilson How Many Left? Spotted 6
HerronScott How many left in the UK Triumph 6
03RedSRT4 Our Jensen Healey restore project, many questions. Other British Cars 35
JPSmit Too many cars too little time Other Cars 4
N craigslist post - many MG parts MG 1
T I'm an idiot / Hazards of too many projects / help Triumph 9
W How many carpet clips... Spridgets 8
richberman How many takers for collapsible steering? Austin Healey 12
S MGB-GT Too many MGB GTs.......? MG 3
drambuie How many more core's can a stock radiator handle Austin Healey 8
G 1500 Registry [how many here?] Spridgets 17
B How many ways can you say UGLY!!!! Spridgets 25
T TR6 How many alloy locating dowels on TR6 trans Triumph 6
Newkie Trim moulding? How many clips? MG 5
Bremer TR2/3/3A How many ground straps on a TR3A? Triumph 4
