Hotrodding a Fiat 600 with Fiat 850 motor/ trans ?
Re: Hotrodding a Fiat 600 with Fiat 850 motor/ tra
yes your hot rod Fiat , how did you get 1300cc out of it ?
thanks
Beaulieu
Bealieu, the engine in mine started out as a 1200 from a 124 sedan, and was bored to 1300. I didn't build it, so am sketchy on the details. The rotation has been reversed to allow it to run through the stock 850 gearbox.
Jeff
[ QUOTE ]
Jeff
[/ QUOTE ]
ummm never heard of that one , so now it runs the "normal" direction like all other cars
(I thought stock 850s ran the "normal" direction)
ohh well more confusion....
Beaulieu
Well, as far as I can figure, the 124 was front engine, and the 850 was rear engine, so it would make sense to have different rotational directions.
However, this is my first foray into Fiats, so I may be talking out of my hat!
Jeff
Had an 850. Never again. Glad you're having better luck. It was a neat little car...
Ben, this thing is a Track Day only car. It's amazingly quick, with the 1300 in it, but, it's still an 850, if you get my drift.
A lot of fun, but I wouldn't want my sister to marry one. /ubbthreads/images/graemlins/grin.gif
Jeff
Some day I will get to my Fiat 600 Abarth Sedan just after I finish the Gt750 Abarth. Check it out at www.abarth.ca
A "Double Bubble!" You lucky dog, Mark.
Now, if I can only find the reverse rotation setup for a 1200........
Jeff
Oooooooooh.... I like the dubble bubble. <drooooooooooool>
Buy the 850 car you can use the front spindles and disc brakes on the 600. The 850 will go into the 600 with no cutting of sheet metal.
Cheers
Mark
[ QUOTE ]
Buy the 850 car you can use the front spindles and disc brakes on the 600. The 850 will go into the 600 with no cutting of sheet metal.Cheers
Mark
[/ QUOTE ]
Hi....I thought the 850 motor turned the wrong way for a 600 transmission ?
is there an easy way to put the 850 transmission in also ?
thanks
Beaulieu
You need to find a Fiat 127 cam there is no fuel pump lobe so electric pump is mandatory. You need to contact people like. Bayless www.baylessfiat.com or PBS www.pbseng.com or these guy are in CA
Fiat Parts www.fiatplus.com
They will help you out big time.
Mark
ummm OK , a Fiat 127 cam will make the 850 motor run backwards, good to know.....
This is all "greek" to me , but I know that many parts interchange between motors ,
thanks for the info.....
Beaulieu
Just what in the heck are you building anyways?
Reversing motor rotation sometimes is more than a backwards cam.
rear main seal, timing cover seal, water pump impeller, possibly oil pump rotation, and starter rotation might be affected.
Do some home work first.....contact the names in previous posts above.
