The relay will have numbers on it
86 and 85 will be for the horn and 87 and 30 for the switch. You can run the brown/green (hot) to 86 and 87 and the brown/black (ground) to 30. You would then run a line from 85 to the horns and then brown/black (ground) from the horn.
OR you can run brown/green to 87 and a separate hot wire (directly from battery or solenoid) to 86 but still brown/black (ground) to 30 and wire from 85 to horns.
you can see it here
https://www.mp3car.com/the-faq-emporium/117895-faq-relays-how-they-work-and-how-to-wire-it-up.html
BTW since they are all just switches, there is no polarity issues so as long as you get the pairs right, you are good to go.
you can see it here
