T
Tinster
I could not find the original thread on this but
I thought it important to post this info.
The Macy emergency hood release DOES NOT OPEN
the Moss aftermarket hood latch. Field tested today.
I installed the Macy as a backup release to my other two
backup releases simply because I had it lying around. The
OEM hood release failed in a parking lot today. I pulled
the Macy to see what would happen. It slipped off the
shortened latch pin and fell apart.
I drove home before I tried my thru-firewall emergency hood
release. It worked perfectly. So, if you are installing a
Moss aftermarket hood latch be aware, the Macy might not work.
[/img]
Hi Guest!
