poolboy
My thoughts on what was happening due to the combination was that the cam immediately began working on the bottom of the lifters. The pictures don't show the concave surface that developed when the valves ran out of spring compression. As a result of the stress, one rocker eventually broke and one had a hairline.
Richard Good replaced the broken ones and machined the others to his more recent design that prevented the pushrod from being trapped awkwardly in the rocker arm's socket.
That was what we originally thought caused the rocker to break.
After replacing with the new version, I started hearing that unusual noise.
I drove around for several weeks trying to either figure it out or hope it would just go ahead and break..while I was close to home.
The noise it turned out was the disintegrating lifters.
Everything in the crankcase needed replacement except the pistons themselves.
I now have 1300+ miles on the new engine and so far so good.
I kept the RR's but with a new post 72 stock cam and it runs very well with lots of torque, as much as I need for passing and coming out of curves.
