Carlbanan56
I have a question regarding my MGB form 1975. The engine won't go down in rpm while idling and I have backed out of the idle screw. I could come up with two theories for this.
The first one is that the timing might be wrong. I have set the timing myself with a strobe light but I am not sure I have done it right. When I set the timing I lined up the indent in the flywheel (Check the picture) with the TDC mark.
Then I marked the TCD and about 10 degrees BTDC on the flywheel. Then I used the timing light to line up the marks (with advanced timing removed). I have got some backfiring as well and that's a symptom of bad timing.
The other theory is that I have an air leak and therefore the engine is sucking in air somewhere. I am not sure how to test this.
Alla answers are greatly appreciated.
