GregW
[ QUOTE ]
And speaking of tri-carbs, GW, I have been reading about your flat slide to the dark side with interest, I have fooled with a number of these on HD's (honorable maker's original intent!) and Volvos, of all things, and can tell you that they work. In theory and just judging from pictures, lengthing the intake line via plenum and/or air horns should give a broader power curve, think Helmholtz, a bit of bottom end torque and a bit of top end HP.
just my .02.
Dave G.
[/ QUOTE ]
Hi Dave,
The distance from the head to the outer circumference of the air cleaner is maxed out now on the front and rear carbs. I had to mill about a ¼” off the carb adaptors just to get everything in. Wound up using rubber air cleaners so they could flex a little. If I go to a smaller cleaner, I will starve the engine at higher RPMs. Once I take the car on the road and load the engine, I’ll know more. I may have to fabricate a common air filter that is wedge shaped (narrower at the bottom).
just my .02.
Dave G.
[/ QUOTE ]
Hi Dave,
