BwanaJoe
I'll give that a try. As for the filter, I didn't they they were ever full of fuel.Late to the discussion, but you can also do a test by pulling the choke cable slightly, enough for the first inlet on the starter box to bleed in fuel. If the problem stops, you are starving for fuel. I am experiencing a fuel starving problem right now, however I have three ZS carbs and I think the mechanical fuel pump, (original type) is not keeping up with the amount needed. I get stuttering through all gears and looking at the plugs, they're looking very lean burn. I also installed a glass fuel filter inline just in front of the carbs, and it always looks empty, or very little fuel in it. So, I'm looking for advice on a better fuel pump.
