weewillie said:JPSmit said:Dizzy is probably OK - I think it is a carb issue - can you check the numbers on the needles? they might be different.
But why would it run fine for years and then suddenly go off,
if the dizzy was even slightly loose it would alter the timing and then it would run like junk. wouldn't it ?
true though I am assuming it would not run and then run rough and then run good again. Easy enough to check though - start it and see if you can turn the dizzy - gently - a fraction of an inch at a time.
