Mice packed my heater box and chewed the blower motor wires. Not realizing this I turned it on and a small fire started. I was able to put it out before any serious damage happened. My heater box is out of the car. I re-soldered the motor wires, and hooked it up to the battery and nothing. Before I take the motor apart, I wanted to ohm it and see what was happening before I took the motor apart. When I first turn on my ohm meter it reads 1. When touch the two test leads it reads zero. When I hooked up the positive test lead to either green wire and the negative test lead to the negative, the meter remains unchanged at 1. I am confused by this - can someone help me out?
Kevin
Kevin
