I am currently restoring a early 1958 100/6 I bought the car that the previous owner took apart some 35 years ago. I am at the stage of panel fit and alignment and need to know if someone can measure the distance (in a straight line) across the two rear fenders at the shut pillars.
At the center of the piping (if your car is together) would be fine , So far I have two measurements. One @ 51" even, and another @ 51-5/16"
I am trying to determine the average measurement of a few different cars.
Also, If anyone has a car that is apart, can you tell me the measurement between the sill and the door when the door is closed.
Not the door gap at the rocker, but the outer sill to the part of the door where the interior door panel mounts IE 5/16" 1/2" 3/4" etc. MM will be fine if that is what you use.
Thanks in advance to everyone.
Paul
