Hi all,
My newly purchased (and newly running!) TR3B is missing the upper radiator support rods, Moss part 850-260. On the Moss site, the diagram shows a couple of washers, a nut, and a grommet. However they specify TR4A only for the washer, grommet, rubber washer. TR3B is only called out for the nut 848-850, but the description seems more to describe the lower radiator mount to frame rather than the nut in the illustration.
[TABLE="class: PlateDetailTable, width: 100%"]
[TR="class: PlateDetailItem, bgcolor: beige"]
[TD="class: PlateDetailItemIllKey, align: center"]55 [/TD]
[TD="class: PlateDetailItemProdCode, align: center"]315-050 [/TD]
[TD="class: PlateDetailItemPrice, align: right"]$0.25 [/TD]
[TD="class: PlateDetailItemDescript, align: left"]
[TD="width: 100%"]WASHER, plain[/TD]
[/TD]
[TD="class: PlateDetailItemApp, align: left"]TR4 from CT1016 [/TD]
[TD="class: PlateDetailItemQtyRqd, align: center"]4 [/TD]
[TD="class: PlateDetailItemQty, align: center"] [/TD]
[TD="class: PlateDetailItemButton, align: center"] [/TD]
[/TR]
[TR="class: PlateDetailAltItem, bgcolor: palegoldenrod"]
[TD="class: PlateDetailItemIllKey, align: center"]56 [/TD]
[TD="class: PlateDetailItemProdCode, align: center"]680-640 [/TD]
[TD="class: PlateDetailItemPrice, align: right"]$2.95 [/TD]
[TD="width: 100%"]GROMMET[/TD]
[/TD]
[TD="class: PlateDetailItemQtyRqd, align: center"]2 [/TD]
[/TR]
[TD="class: PlateDetailItemIllKey, align: center"]57 [/TD]
[TD="class: PlateDetailItemProdCode, align: center"]680-650 [/TD]
[TD="class: PlateDetailItemPrice, align: right"]$1.85 [/TD]
[TD="width: 100%"]WASHER, rubber[/TD]
[/TD]
[/TR]
[TD="class: PlateDetailItemIllKey, align: center"]58 [/TD]
[TD="class: PlateDetailItemProdCode, align: center"]848-540 [/TD]
[TD="class: PlateDetailItemPrice, align: right"]$0.40 [/TD]
[TD="width: 100%"]NUT[/TD]
[/TD]
[TD="class: PlateDetailItemApp, align: left"]TR2-4 [/TD]
[/TR]
[/TABLE]
I called Moss, they weren't sure. Has anyone ordered this part(s) for a TR3B, or know which parts are required for a TR3B? https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29121#54
thanks
[/TR]
[/TR]
[/TR]
| Note: | TR4 illus. TR2-3B bolts go from under the frame upwards to the radiator. |
[/TR]
[/TABLE]
thanks
