sparkydave
Help! A while back, I had trouble with gear oil coming out of the left end of the rear axle. It found its way past the paper gasket between the axle disk and the wheel hub, soaked the brakes, and finally made a nice pattern on the rear wheel. I cleaned it up the best I could back then, and between a squealing brake on the front, and the apparent inability to get oil out of the brake shoes, I decided to get new brakes all around. Here's the rub:
I'm STILL getting oil out of the left side! /ubbthreads/images/graemlins/mad.gif The wheel bearing seems to have a fair amount of oil in it, and there was yet another load of oil in between the disk and the wheel hub. So, a few questions. Why is this only coming out of the left side? Is there something I'm missing that's supposed to keep the oil out of the wheel bearing? The right side is dry, and just has wheel bearing grease in the bearing. Does this mean I now need to repack the left bearing with grease? Sorry for all the questions, but it seems this oil situation needs to get fixed before I can finish the brakes.
