TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin.
angelfj1
Was just out to the shed getting Gray Lady ready for our annual trek to Boyertown, PA for Duryea Day. Seems that the passenger -side bonnet hinge pin decided to fall out and its missing. :mad-new:
I don't have an extra pin or hinge, so does anyone have a solution that will get us through the day?
Thanks
If your local hardware store is still open, they should have a split spring pin that will fit.
I have replaced the hinge pins in the boot hinges with cap bolts & nylocs. I did this to make it easy to install and remove the luggage rack that locates in those holes.
I see no reason why this wouldn't suit as a temporary fix for a bonnet hinge.
I once used a bit of leftover brazing rod.
But with pretty much any of the temporary solutions, I think you'll want a new hinge later on.
Thanks gentlemen - found some of those split pins at the local HF. I must be getting too old to think of obvious solutions like that.
Cheers, Frank
