Help me price my Bugeye?
David_Doan
Hi Jim. Here is a picture or two of the red interior. I also included a picture of the engine bay.
Jim, I really like what you did with your car (I'm doing a lot of the same :smile: ).
  • front tilt
  • convertible top hardware is gone
  • mirrors on the windshield posts
  • no front bumper
  • heater delete
  • polished carbs
  • stainless heat shield
  • alternator conversion
  • I love the red engine. I did mine in gray and black. Anything is better than the original army green. No offense to the purists.
A few questions/comments if you don't mind.
  • The rubber bonnet supports on the front fenders can go away with front tilt. The bonnet is fully supported by the front hinge. When I did the bodywork on my car before front tilt conversion I noticed that over the years these had made dents in the bonnet. With a front tilt setup they are likely either not touching when it is closed, or are pushing, creating an impression in the bonnet.
  • The missing shifter cover may detract from the value. (maybe didn't fit after 5 speed conversion?)
  • since the convertible top hardware is gone, why not fill in the holes? (can see 3 of them on the right-rear fender)
  • Can you share where you got the side mirrors? I've heard it is hard to get the passenger side mirror to be useful and not hit the door when opened.
  • I'm doing white too, but yours looks amazing. Is it a pearl finish?
I'm sure you will have no trouble selling this car!
Jim_Gruber
Jim,
Looks fabulous. A picture of your car is now hanging on my wall for inspiration.
Seat Kit and Carpet Kit came from which supplier. Looks really gorgeous.
Stripes - Painted over the white or did you do a multipart masking with stripes laid down first and them remask and paint white?
Paint color?
Thanks for the pics.
59diamond
It is a beautiful Bugeye. One thing I really like are the mirrors. Can I ask where you got them and about how much do they cost?
bug_sixty
Well, sounds like Jim gets stress re..lief not the opposite... So goes it... Look at it as a resurrection from the scrap metal guy...
Coastalman
The mirror looks like a Harley mirror. I have one on my BE and it screws right into the captured nut for the front windshield screw. Best mirror I could find for the car.
Charlie
J
Jimflorida
Thanks for the comments, guys. I've been prepping for my move and have not had time to reply. David, that is good idea re the bonnet supports--they really don't serve any purpose. I have not gotten around to putting on the shifter cover or convertible top yet, but they are sitting ready to go on. The white paint is a pearl called White Diamond, which is a GM color that they used back in the day on Cadillacs, etc. I used the PPG Deltron DBC paints, with the DCU clear. I did use the Harley side mirrors.
Jim, I painted the white, did the red stripes, and then clear coated. I got the seat upholstery, carpet, etc from Moss. (I think I got the red convertible top from the UK). I think it looks fine, but would maybe spring for the leather seats if I was to do it again. I spent so much money on everything else, I might as well have done leather.
Jim
Jim_Gruber
Fabulous paint job. I used Deltron on the hull of my sailboat when I repainted it. Paint is hard, hard, hard. Had many a collision on the water racing 17' One Designs and my boat usually came out without a scratch.
J
Jimflorida
Yes, that is nice paint to work with. I use a HVLP spray system and the problem with doing this in the garage is that (especially with the HVLP unit), the temperature has to be just right. If it is too hot, as it almost always is here in Florida,you have to deal with a good bit of orange peel. If the weather is right, then the paint and clear coat lays out like glass. I enjoy painting, but when you paint a car once a year or so, it is hard to become a real expert. But, if you don't mind doing a lot of sanding and buffing, you can get a nice job.
Jim
59diamond
In the thumbnail of the engine compartment I see where the back of the bonnet fits closed there is a rubber ridge at the back where the bonnet meets the body of the car. Mine doesn't have that rubber piece and the bonnet has scratched off the paint a little bit from opening and closing the bonnet. My question is did bugeyes come with that rubber ridge and if so where do you get one?
Jim_Gruber
Bill,
Best source for the rubber is MacGregors/McGregors in CA. They are the same guys that sell the Bristleflex Door Seals. Their rubber pieces fit and you can do it yourself vs. the MOSS Kit that needs 3 people to install to pull and stretch to fit. They always have an add in the back of Class Motor Sports. Call them on the phone. They don't respond well to e-Mail.
Jim_Gruber
Hey Bill,
PING me about the price for those hubcaps you've got for sale.
Jim, you sound like maybe you're losing your garage in this move, how about a cheap storage building to keep the Bugeye in?
On the engine, for anyone interested, it is stage I rebuild done by me. Here's run down to what was done.
Bore .040 over, I pretty sure we used the 9.7 to 1 piston, but i have to look back at the build sheet to know for sure.
APT nitrated slot drive VP276 cam with the good APT CF-04 lifters, and a Powertune adjustable vernier cam gear set up with the cam timed at APT's instructions
Crank was index reground to .010/.010
Connecting rods were cleaned, bead blasted, big ends re-sized and new ARP 206-6001 rod bolts installed, and balanced within 1 gram of each other
King tri metal rod and main bearing
New slot drive oil pump
New water pump
Gerard rear seal kit, and custom aluminum back plate for the Datsun 5 speed
Payne gasket used
Cylinder head was cleaned , beadblasted, re-cleaned, new bronze guides, new SS valves, new dual valve springs, the head was pressure checked, has new hardened exhaust seats, all seats, intake and exhaust have a 30/45/60 multi angle cut on them done on a Serdi head machine. The head was also resurfaced, all seat pressures set on the valve springs
Rod and main clearances are .0015" and all machining was blueprinted by me, as I always do with these engines.
ARP head stud kit
Rebuilt rocker arm assembly
All common fasteners were replaced with new grade 8 hardware
Engine paint is Duplicolor Red at Jim's request, all painted components were painted separately, and then assembled, this is the only way I do this, so you can see the details of the yellow zinc fasteners.
I also made a top timing pointer, and marked the harmonic balancer with a TDC mark to reflect this. I'm pretty sure Jim provided a new balancer from Moss for this too.
This is a good 80 HP 1275 blueprinted engine, and could easily be 90 HP with head porting.
Jim, I think you are being too modest when you say this isn't a show car, I know you built it to use, which anyone in their right mind would do, what good is having a super model for girlfriend, if you can't sleep with her :smile: Anyway I believe your car could easily win a show,and it should command top dollar on the open market.
With all that said, I sure would like to see you keep it, and enjoy it.
As for value, what you have done to your car what will probably command the most money return, even though you probably want get all your money back, you get more of a return than some. For example my friends David Harrison Bugeye, is a even a more obsessive build with a lot of things that someone may, or may not like in a Bugeye, like a SC/CR gearbox, or even the 1380cc engine, and like my friend Alan Gilbert's build, this is going to be even higher end build than David's , Alan is building the fantasy Bugeye , obsessive is a understatement in this build, and Alan is probably the most obsessive guy I know :smile: , but at the end of the day, people don't pay extra for obsessive, says the guy with a $65K MGB vintage race car worth maybe $20K if I can find a sucker :smile:
Gundy
Jim, <snip>
Tis a wonderful obsession none the less. Jim's Sprite is clearly a fine example of a show quality driver.
No way I'd ask less than $16-17K for it. Personally I think it's worth closer to $20K or a MGB vintage race car.
:cool-new:
I'd never get my investment back on my Sprite. How much is invested is a secret I'll carry to my grave.
Even my wife is clueless about THOSE numbers.
It will never return what my old FJ40 Cruiser did.
Took about 30 years for my $1500 investment to mature. Just sold it for $15,000. Rust bucket, dented from hard trail use, bad brakes
and badly needing paint. Buyer didn't care.
P.T. Barnum would be proud.
Maybe in 30 years the Sprite will be worth what I've invested....but I doubt it.
:playful:
nomad
Find a way to keep it!!:encouragement:
You'll kick yourself later if you don't!
My .02!
Kurt.
S Help Setting Selling Price Spridgets 6
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
