Help installing toggle dip switch on dash for lights.
55modified
I need a light "dip switch" for my headlights. The floor switch can't easily be reached due to pedals in my car. Would like to install Lucas style toggle switch on dash for this function. Anyone done this? What type of switch would I need? Three way? On/on? Most are just on/off so I don't think those would work?
vette
I haven't looked at that circuit for awhile but i would suspect that it is a three way switch. 3 terminals, one is common the other 2 would be on or off depending on the switch position. I bought the toggle switches I used for my twin fuel pumps from NAPA. They can supply almost any configuration, look at their website. My fuel pumps are electrically interlocked so that only one will come on at a time. I used double pole/double throw toggle switches from NAPA for that. See pic.
HealeyRick
vette
Rick, what you discribe would be the same as what is called a 3-way switch if you have an off position in the middle. Hot wire would come in to a middle terminal then the up position could be used as the high beams and the bottom position could be used as the low beams. Ideally, there would be no need to have an off position if you are using the original dash headlight switch as the off/on switch. In which case you would have a toggle switch that just moves from on to on with no center stop position. but it would still need 3 terminals in the back.
Keoke
That's COOL Rick just leave the normal dash switch on all the time.--:encouragement:
Course when i first saw it i thought it was the gear shift lever.-----:congratulatory:
DerekJ
You don't need a 3 way switch. I still have the normal 'pull' switch for the lights and just use a 2-way switch on the dashboard for the main/dip. It is the simplest solution as all you are doing is replacing the 2-way floor switch with with a 2 way dash switch.
55modified
55modified
DerekJ, so just a simple on/off toggle switch? What did you use exactly?
I like the idea of constant on. Not sure I want "off" in middle between throws.
Michael Oritt
If I were doing it I'd opt for a three-position switch: Up=on, middle=off, down=momentary on, the last being used to flash the lights at oncoming traffic for whatever reason.
RAC68
Hi All,
I am a little confused why you would put the dip switch on the dash and not just keep it on the floor? I would expect there are enough to address with your hands and dipping the headlights seems to be just another.
Have you installed relays to off-load the total flow of lighting power from passing through the dash harnesses? If so, are your driving lights powered only with High Beams as is required in many US States? As I see it, if so, the installation of a 2 or 3 way dash dip switch should be relatively easy by running a line from the dash dip switch as a replacement of the floor dip switch.
Am I missing something?
Ray(64BJ8P1)
HealeyRick
Hi All,
Ray(64BJ8P1)
Because V8. No room for your left foot to operate the switch if you've swung your pedals to the left to make room for the engine:
DerekJ
I use a long switch like the Holden example. (I think its the same but i can't actually access the Holden site!)
See attached
Keoke
SO:
What chu do if driving lights go out???????
vette
Hi folks, the nonmenclature of the switches is a little misleading. And I might admitt that in some parts of the electrical industry the names might be used differently but the name 3-way implies that the switch has 3 terminals. you would have a common which is the power to the switch and then two hots leading from the switch. The switch would be on in one direction or on in the other direction. There is no diffenate off position. As an example, when you have a light in your house that is controlled from 2 different switches at 2 different locations, those switches are 3-way switches. They have 3 terminals but alas there would only be 2 of them to control the light. If the light is controlled from more than 2 locations then the other switches in the circuit are called 4-way switches. Yeh, i know, it doesn't seem to make sense but that is the convention of naming switches configurations. so the have a switch that will turn on the low beams in one position, and the high beams in the other position with neither being on at the same time and no definate off position, you will need a 3-way switch. See drawing.
RAC68
Rick,
I see your point where the modification of peddle location eliminates access for any reason in this tight real-estate condition.
Keoke,
Because of the state requirement to have the driving lights on only with the high beams, the dip switch dips both the high beam and driving lights together. Keep in mind that I am using 3 relays (low beam, high beam, driving lights). This is effected by having the dip switch gated to the high beam relay and the driving light relay. Yes, the driving lights can only be turned on with the high beams active and not with the low beams or independently. Since I have little use for the windscreen washer, I have imbedded the driving light switch within the washer pump button.
I have had the driving lights since the car was first purchased new and find that their long narrow beam was very complimentary to the broad wide beam of the high beams. I see little benefit for me to have the deriving lights on alone, however, could easily change this restriction if I decided to install fog lamps in place of the driving lights.
Ray(64BJ8P1)
Keoke
YEP,BUT
Because of the state requirement to have driving lights on,IF they fail you are required to retire to the side of the road.
Keep driving lights separately energized N get home when head lights fail.:eagerness:
Keoke
Nomenclature:
For Automotive Switches & Relays
Rocker/ toggles witches & Relays of different styles are referred to as - SPST, SPDT, DPST, DPDT, in On, Off .12 Volt Automotive r DC circuits.
Where:
S=Single
P=Pole
D=Double
T=Throw
John Turney
I have an On-Off-On switch, but one of the Ons is spring loaded. Off is low beam, On is high beam. I use the spring loaded position to flash the high beams. Since I have the OD switch on the shift knob, the switch went in the OD switch spot. Very convenient.
55modified
55modified
Where did you source that switch? What brand?
Bayless Help please installing bonnet release cable Spridgets 8
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
RickPA Need help installing steering idler oil seal Austin Healey 6
2wrench TR6 Help installing door handles/window regulator handles. Triumph 9
I Help on installing side curtains and rag top on Bugeye please Spridgets 4
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
A Serious help needed !!!! BJ7 Installing a new soft top Austin Healey 9
I TR6 Help installing TR6 door pulls and fuzzy seals Triumph 14
Johnny Help installing a transmission. Austin Healey 13
S Installing 3 pc. cockpit chrome. [b]I need help[/. Triumph 5
bighealeysource Help with installing new top on 100-4 BN1 Austin Healey 4
bighealeysource Help on installing carpet on BN1 Austin Healey 4
S Help! Installing Rubber on Header rail MG 5
DerekJ Installing Sport Coil - Help Please Austin Healey 28
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
