Heater hoses
Griz
Need some help locating a source for the hoses to and from the heater core. Moss does not sell them. Looks to me like the proper size is 1/2 inch ID X 3/4 inch OD, which I can only find in red hose at the local hardware store. All they have in the proper black hose is 5/8 ID x 7/8 OD, but 7/8 is way too big to fit through the rubber grommets in the firewall. Any suggestions?
Griz
Griz
Griz
Thanks, didn't even think of them because I don't recall ever seen "bulk" hose reels in the auto stores. But I'll give them a try.
steveg
I think BCS has them in the correct, molded shape; the hoses have to make a couple sharp turns and can get kinked.
Bob, are you sure?
I've never had any problem with using plain old black hose from the roll at the auto parts store. The two elbows on the vent tube from the crankcase to the tee on the valve cover are molded, but the heater hoses make only gentle curves.
I haven't replaced them in a few years, but I always thought it was a pretty tight bend up from the core and under the scuttle. I used regular hose--IIRC it's half-inch--but found out about the molded hose afterwards and would have used it had I known about it. I would just have felt a bit more comfortable with molded hose, but I've never had a problem with the generic stuff beyond the usual life-expectancy stuff.
Rob Glasgow
I've always used bulk hose from NAPA. Works fine and no problems with kinking, the curves are gentle enough.
One thing to keep in mind is the supply hose get very hot and if you drive in the summer, it's a good idea to close the shut off valve on the side of the engine so you're not adding more heat into the cockpit. If you want to feel what I'm talking about, just reach up under the dash and feel the heater hose next time your driving.
Griz
Griz
Once again the forum comes through! I found the correct size hose (in black) at a local auto parts store. Fitting it in place I can understand the concerns of some about possible kinking of the hose. But it appears to me from studying several diagrams that the hoses cross above the heater core, i.e. the hose from the left side of the engine block goes to the right side of the heater core and vise versa. Am I correct? If so, this would eliminate the most severe bends in the hoses.
Griz
Keoke
Yep You are Correct.:applause:
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
B Replacement of Heater hoses Austin Healey 13
T TR2/3/3A TR3b temp gauge and heater hoses Triumph 10
M TR4/4A TR4A heater hoses Triumph 3
W TR6 installing heater hoses '74 tr6 Triumph 1
B GT6 GT6 heater hoses Triumph 6
af3683 TR2/3/3A TR3 Heater Hoses Triumph 4
G late model Midget heater hoses Spridgets 5
ecurie_ecosse Heater Hoses. Spridgets 3
A Heater Hoses... Spridgets 5
2wrench TR6 1974 TR6 heater hoses to firewall or bulkhead. Triumph 12
A TR6 TR6 heater hoses. Triumph 1
77_MG_Midget heater hoses on a '77 Midget Spridgets 4
V TR6 TR6 Radiator and Heater hoses Triumph 8
mbrooks BN2 heater hoses Austin Healey 3
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R TR6 Heater control bezels TR6 Triumph 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
6 Smith heater rebuild Austin Healey 8
Healey Nut Heater Box Installation Austin Healey 4
CJD TR2/3/3A Heater Delete Triumph 15
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
F TR6 Heater Triumph 7
C Water flow in heater? Austin Healey 5
C Heater knobs won’t stay on... Austin Healey 4
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Austin Healey heater assembly Austin Healey Classifieds 1
C TR6 Heater Removal Triumph 2
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
