Heat Shield finish 66 Type
AH67
Hi All,
I have a 66 E type and I am replacing the Heat Shield. Got a new one from XK unlimited an unsure if it needs to be sprayed.
What is the correct finish please?
Deleted member 8987
JCNA mentions heat shields...but no finish. Downpipes light rust accepted. I did judging ONCE for JCNA, and the guides are NOT inclusive, leave a whole lot out, and results in long, heated arguments.
Fortunately, the judgees usually have their poo together with documentation and it's all good.
LarryK
Should be galvanized finish, can use a heat paint of same color to help prevent the rust color from sitting. JCNA judges were pretty persnicity. We drug a 79 XJ12 thru 5 states and saw completely different judging. I grew up with original Jags but what I saw new doesn't hold up to some judges. Took 10 shows to get a National Champion and $79,000. If shields are for carburettor covers, they are polished stainless.
Grantura_MKI
Hmmmmm who said that?
And speaking of judging, at one JCNA show the blind mice decided to use my etype for a judging class. Took over two hours to judge mine and about 7-8 minutes of each of the other cars.
Not a good out come for me.
LarryK
I took the above mentioned XJ12 to a National Champion but with alot of mixed up judging. Went to Tulsa got 100% on engine bay and 0 on the boot. Car was sprayed Fern Green and boot was still silver. That was Tulsa Club and Houston judged that. St. Louis judges did a 100% in boot and 0 on engine, because of wrong hose clamps. I had original brochure and protested with 2 out of 3 judges giving us a 99 second place. I saw a Series one E in drivers given a 100, then tried to talk him into concours class. No way was he going to paint and rechrome for them to pick him to death. Couple years later he took the preservation class hands down.
V heat shield Triumph Classifieds 7
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
K TR2/3/3A Revington alternator heat shield. Triumph 0
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
L 100/ Moss Heat Shield Austin Healey 2
DornTRoriginal TR2/3/3A Heat Shield Issues Triumph 6
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
T TR2/3/3A Fuel line heat shield Triumph 39
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
J Side exhaust heat shield Austin Healey 23
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Heat shield for tranny cover Triumph 4
R Heat Shield Detail Austin Healey 3
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
tahoe healey Dynamat heat shield Austin Healey 8
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
HealeyDave Intake manifold heat shield fitting issue Austin Healey 2
R TR4/4A Tr4a, alternator heat shield Triumph 9
G HEAT SHIELD! Austin Healey 10
R No Heat Shield Cause Dieseling? MG 1
I How do I install Bugeye heat shield? Spridgets 4
Gliderman8 Heat Shield - will it solve my problem.... Triumph 15
I Bugeye heat shield color? Spridgets 11
Dudly Heat shield Triumph 0
19_again Carb heat shield MG 7
bigjones Vapor lock. Heat shield for fuel pump? Spridgets 5
M SU Carb Heat Shield Triumph 6
c5racer Gaskets with the heat shield? Spridgets 0
T Heat shield pictures- anyone have one handy? Triumph 3
J Heat Shield Material / Carpet Dye? Austin Healey 15
Brosky Goodparts Triple Carb Heat Shield Triumph 16
Brosky Triple ZS Owners - new Heat Shield from Goodparts Triumph 7
19_again MGB MGB exhaust heat shield MG 3
Trick6 Tri Stromberg Heat Shield Coming This Spring/Summe Triumph 16
LastDeadLast Heat shield for HS8 carbs Triumph 3
tony barnhill MG Midget Heat Shield Spridgets 30
newmexTR3 TR2/3/3A TR3 Carburettor Heat Shield install Triumph 4
Steve P. '78 Midget carb heat shield? Spridgets 1
T Ratco Cable + Heat shield Triumph 30
6773 heat shield Spridgets 7
mjobrien Cockpit Floor Heat Shield Austin Healey 4
kyreb1862 MGB Heat Shield Color On A 77 MGB MG 1
Musicman Heat Shield Triumph 8
A SU H1 heat shield Spridgets 5
LastDeadLast Stainless Heat Shield for Triple Carb Manifold Triumph 7
R Exhaust Heat Shield Austin Healey 3
