There's a few good articles that show bench testing the Type A O/D while mated to the trans, but is there any reason why the O/D can't be tested separately for initial testing? My thought was to install a dummy input shaft that's typically used to line up the splines. Is 800rpm sufficient to check the O/D pressure level?
Hi Guest!
