dklawson
I'll repeat my earlier POR comment and expound on it.
POR engine enamel is enamel, it is NOT the product you hear advertised as a rust preventative coating. Don't use POR enamel as a primer because ANY paint you apply over it will lift it.
POR-15 (the coating you hear about for rust prevention) is a particularly awful primer. It's made to encapsulate treated rust and leaves a nearly glass-like urethane coating behind. Nothing sticks well to cured POR... not even their own "Tie Coat" primer. There are ways to improve this but using a regular paint and primer are better and easier choices.
If you're painting an engine, prep as usual with a special focus on degreasing the block. Acid etching will help a little, but isn't as necessary on cast iron parts as they are already rough. Prime if you want with a normal primer. No, you don't need high-temperature primer. The block better not get hot enough to damage the paint or you've got more serious problems to worry about than paint.
