AUSMHLY
Well guys, I'm at it again.
Now that I figured out how to illuminate our gauge lights, I've taken on a new project.
How to implement a courtesy light set up.
I will be using a door pin system, hidden of course.
I will be comparing led vs incandesant as the lighting source.
Here's a sneak preview of what I will be installing.
If you, like most of us, do not have infrared eyesight; then at times you have probably found yourself fumbling for the ignition switch or seat belt in the dark. For people like you we have developed this solution, i.e. our car interior illumination unit. After your stepping in and closing the door, this circuit makes the interior light burning for an adjustable time. But there is more. With a simple push button you can interrupt that time, or you can switch the light on or off using that same push button. A safety circuit automatically switches the interior light off after 5 minutes.
Technical specifications
- Switch off delay adjustable between 0 and 60 seconds.
- Push button operation for :
* interrupting the delay.
* switching on lights (with a switch off delay of 5 minutes)
* switching off lights.
- Simple connection to practically all cars.
- Push button supplied with kit.
- Current consumption : 13mA min.
- Secured against polarity reversal of the power supply.
Hi Guest!
