I have been a big YouTube watcher the last few years. After all these years of bodyworking, I came across several tools that I did not know about. I am sure you guys have heard of them, but here is the list I just ordered...for the next bodywork project! I still have a lot of aluminum sheet metal work on the Stearman, so I am very excited to add these tools to the toolbox.
First, the shrinking disc is used on a grinder. This gradually shrinks high spots back down to level. You use the disc to heat the metal, and then quench with water. Same as torch shrinking, but much more subtle:
Next is the spoon. This is just like a body hammer, to be used with a backing dolly. The difference is sometimes the hammer is too small. I used to use another dolly to hammer with...but this is the preferred solution. Use it to "slapp" off dolly to bring up low spots:
Buy Fairmount Tools Professional Dinging Spoon Slapping Autobody Dent Repair | RED: Dollies - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
This is a cool tool that works to remove the little "dots" of metal that are left after a lot of metal shaping...the bullseye pick. It is used to pic at the little low spots, by hitting a small area "off dolly", which means you are tapping slightly away from the backing dolly. The pick and dolly are on the same tool:
This is a pneumatic orbital sander. I have needed one forever, but finally bit the bullet. It is good for all sanding needs, but for bodywork you use it quickly over the area you are working to highlight the highs and lows:
Finally, here is a body file that can be adjusted to the shape you need. By turning the nut on top, you can bend the file to a convex or concave shape. This makes following the shape of the panel much easier:
pizarra Adjustable Milled Tooth Car Body Polisher Files Metal Panel Polishing Curved Tooth Steel File Holder(Medium) - Amazon.com
www.amazon.com
Like I said, I am sure you guys knew about most, if not all of these tools...I'm slow. But, I am looking forward to trying them out.
