TR4/4A Head gasket sealer question
tdskip
Thanks for all of the help and coaching on this, first time doing a head r&r.
i picked up the Ultra Cooper gasket material, it says to run a a bead aroind the bolt openings but should I also run one around the liners? Wondering if that would help, but also don't want any gasket materials in the cylinder openings of course. I am thinking the metal rings on this gasket would take care of it but seemed work asking.
Thanks!
T
tdskip
Glad I asked - I picked this up;
thumbnailer.aspx
poolboy
On the gasket. I hang it up with a wire thru one of it's small holes and spray both sides with several light coats.
Do that several hours before installation.
T
tdskip
Thanks guys - picked some of the Cooper spray up today and just coated the headgasket on both sides.
Appreciate the coaching!
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
J Head Gasket Sealer Spridgets 9
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 3
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
DrEntropy MGB Head gasket R&R goes on... MG 13
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
R BJ8 Cylinder Head Gasket Austin Healey 38
B TR4/4A Head gasket won't lay flat Triumph 13
Michael Oritt Head gasket question Austin Healey 17
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
Simmo TR2/3/3A Head Gasket Triumph 4
KVH General Tech Head Gasket Triumph 10
RJS General TR Head Gasket Test Fit Triumph 5
D TR2/3/3A head gasket... which way up?! Triumph 8
KVH TR4/4A Blown Head Gasket? Triumph 12
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
H TR4/4A Head Gasket Issue Triumph 4
Got_All_4 TR2/3/3A What direction does the head gasket go? Triumph 4
T TR4/4A Best head gasket for a 4A? Triumph 12
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
B Victoria British Head Gasket Austin Healey 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
G Payen XK engine head gasket -- which side is the top? Jaguar 2
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
S Tolerance for head gasket Austin Healey 10
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
Gliderman8 TR6 Question on installing new head gasket Triumph 2
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
B Experience with Cometic Head Gasket for BN2? Austin Healey 8
S SaxMan's Cylinder Head Overhaul / Head Gasket Replacement Thread Spridgets 135
M TR2/3/3A Head gasket leaking in two places Triumph 13
S TR2/3/3A head gasket Triumph 5
AngliaGT General MG MGB GT Head Gasket - What do I need? MG 3
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
O HEALEY 100 Head Gasket Gone ? Austin Healey 10
J Blown head gasket in 3 min. a new record! Triumph 14
