Csarneson
I rebuilt my 1957 100/6 block and have a later 6 port head to go onto it. After an initial break-in period it was clear my head gasket had not sealed well and when I drained the oil it was full of water. I've stripped the top end back and am reassessing what I did wrong. Lots of coolant in the pistons when I took the head off. Clearly I had a terrible seal. I installed the head gasket dry and used one of the standard Moss head gaskets. I am confident that it was torqued properly and my machinist tells me the mating surfaces are flat.
Obviously next time I will use copper-coat, but what else do I need to do? Payen gaskets are no longer available so is there a similar gasket that I can be sure will seal well? I've read that some people recommend the Denis Welch competition gasket, but that's over $300 plus shipping from the UK. Is that the only good-quality option? Obviously the cost of a mistake is much more than even the highest quality gasket so I'm willing to pay whatever is necessary. AH Spares has an all-steel one that looks impressive as well. I've read how other folks use Hylomar around the water passages, but this seems risky. This is not a competition engine, but I need to get it sealed. Advice from you seasoned engine builders?
Chris
Big Horn, WY
Chris
Big Horn, WY
Hi Guest!
