Have TR's ever had locking steering column's?
Johnny
Good day fellow British car enthusiasts. As you can tell from my signature photo my devotion to British cars lies with the Austin Healey marque. However, I would like to know if any TR's were ever equipped with "locking steering column's"? I'm currently restoring a 1962 model AH that did have that feature. The car was shipped to Dusseldorf Germany where that option was necessary. If it's true TR's were equipped with that feature, does anyone on this Forum have one?
Thank you for responding.
Johnny
Don Elliott
I have never heard of a TR with a locking steering column. But while visiting England in 1998, I met a chap with a dark blue TR5 and he had installed a steering wheel and column that locked. I noticed when I parked next to him in the car park at the pub that he had no steering wheel. When he parks his TR5, he takes his ordinary looking key and unlocks the steering wheel from the column, then he removes it. Then he takes the same key and locks the column so it can't be tampered with. I recognized him in the pub. He was the chap with the steering wheel on the bar in front of him.
It reminded me of the Formula 1 race cars where the steering wheel is removed to let the driver get in or out.
DougF
All TR6's after 1969 had the key under the steering wheel to allow for a locking column. I believe it was mandatory for all cars sold in the USA from 1970 on to have them.
tomshobby
I greatly dislike the under dash location of the switch. I have plans to move it back to the dash support.
I would think that anyone knowledgeable enough to hot wire one of these cars would also know enough to punch out the ignition switch lock to disable the steering lock.
I also plan on having the tumblers changed so the key can be used either way. I don't know if they are all this way but my ignition key will fit either way but only works one way. A real pain especially at night.
Andrew Mace
You're right, of course. In my initial response, I was thinking only in terms of pre-1970 cars, especially those built for markets other than the US, when I replied.
Johnny
Johnny
Thanks to all who took the time to reply, greatly appreciated. Now, do you think it'll fit a Austin Healey? The steering column, on which the lock surrounds, is 1 5/16" in diameter, and yes it does fit underneath the steering wheel. I'll take a photo and add it here:
TRopic6
Johnny,
I measured the ignition and steering column lock assy I bought to replace the balky one in my TR6. Looks a lot like yours but I got 1 1/4" for diameter.
Jeff
TR3driver
Great Pumpkin - R.I.P
Shouldn't be that way ... likely your key is worn or damaged so it's no longer symmetrical. You might be able to solve the problem by having someone like Pete Groh read the code from the key and then make a new key by the code.
TR3driver
I've seen a Mach I Mustang with a similar arrangement; except that instead of locking the column, there was a dummy hub that locked in place of the steering wheel. The dummy hub had a bearing inside, so it would just spin freely.
roofman
Keep in mind the TR6 steering shaft has a keyway cut in for the lock.
TR3driver
Which IMO would be easy to add with a Dremel & cutoff wheel.
tomshobby
Hi Randall, that is what I thought too. But the car does not have a lot of miles and the key shows very little wear.
TR3driver
Well the problem has to be the key, since it is supposed to be symmetrical (meaning each side is identical to the other, so the tumblers are lifted to the same position regardless of which way the key is inserted). Possibly it was miscut when the key was made (or copied). But certainly replacing both the cylinder and the key will solve the problem.
Another way would be to take the cylinder out, find which way the key doesn't work, then gently file the offending tumbler until it does. Or if the key lifts the tumbler too high when it's the wrong way, you could work that place and side of the key down a bit (but obviously that won't work if it doesn't life high enough).
Or, you could buy a blank, and hand-match it to your cylinder. I believe TRF sells most Triumph blanks (tho I have no idea which one is correct for your TR6) as do several sellers on eBay.
Johnny
Johnny
Thanks Jeff, that might work because the top part has a screw through it that contacts the column for adjusting. Could you please measure the part that goes up in the steering shaft, the AH one I have measures 7/16" by 8/32".
Thanks again Jeff, I see one on ebay for about $140 that looks brand new.
TRopic6
Aloha Johnny,
The bar that goes up into the steering shaft is 5/16" wide and about 1/2" long (it has a slightly rounded shape on the front & rear ends). It sticks up about 7/32". I tried to add some photos but don't seem to be able to attach tnem right now - I'll post a PM.
TRF has ones that are brand new for about that. I got mine for much less on eBay but maybe I was just lucky.
As for keys, the one in my early '74 (production date Oct 73) has a single edge key, but the one from e-Bay has a double-sided key.
Jeff
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] As you can tell from my signature photo my devotion to British cars lies with the Austin Healey marque[/QUOTE]
You see, we actually kind of like you Healey guys over here.
Platinum
Unlike those MG and Lotus freaks...
TR4nut
Here's the link to the TRF lock mechanism:
Column Lock
I never had one of these on my TR6's, but I think my 78 Spitfire was set up this way.
Randy
Johnny
Johnny
Thanks so much Randy, I have contacted TRF and am waiting for a call. It looks like I might be able to retrofit a TR6 lock to a AH how about that!
/bcforum/images/%%GRAEMLIN_URL%%/thirsty.gif
And a very Merry Christmas to all.
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
Jim_Gruber Remember "The Mite" a beautiful "almost a BE" Build. It's back on BAT and Badder than ever! Spridgets 6
R TR2/3/3A Best day ever [so far] Triumph 1
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
Jim_Gruber Boy was I ever surprised on Saturday Spridgets 11
T Was Sophia Loren ever photographed with a Healey? Austin Healey 2
S Scam or greatest deal ever? Decent BT7 for $15K? Austin Healey 9
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
PAUL161 General TR If i were to ever own a triumph Triumph 10
J Cloth interior in AH-3000? Was it ever fitted? Pleated inserts maybe? Austin Healey 7
Pythias Back and Better Than Ever. Spridgets 7
J Nothing is ever easy! Austin Healey 12
Randy Forbes Healarossa; anybody ever seen, or heard of it? Austin Healey 2
Jake Anyone ever get into their horns? Austin Healey 6
L If you ever wanted an Innocenti... Spridgets 15
Elva164 Videos from my first-ever weekend at Watkins Glen! Racing 4
M Ever seen this ? - early wire hubs for drum brakes Spridgets 10
bigjones Ever re-paint your license plate? Spridgets 22
60TR3A What's The Weirdest Thing Anyone Ever Said or Asked You About Your Car? Austin Healey 28
T General TR Ever wonder why 87mm is a favorite size? Triumph 6
L What is the rustiest, most run down Healey you have ever seen? Austin Healey 56
DanLewis Anyone ever installed a Mercedes hood vent on a Bugeye? Spridgets 5
Basil TR6 The "blokiest" Bloke's car ever built Triumph 12
Simmo MGB Have you ever tried removing the spring clip on the Keylock from inside the door MG 0
S Were Valve Covers Ever Painted Blue? Austin Healey 8
B Anyone ever buy from these guys? any feedback? http://www.northwestimportparts.com Spridgets 6
DerekJ Ever seen wire wheels like this before? Austin Healey 5
glemon Ever seen these wheel covers? Spridgets 5
Nunyas The coolest jackstands I've ever seen Restoration & Tools 3
dougie Ugliest Healey Ever... Austin Healey 8
Mickey Richaud Ever Seen... MG 7
G Spitfire Anyone ever see a Spit look like this one? Triumph 5
N Best Sports Car Ever!! Lotus 2
F Best 4th of July ever. Spridgets 9
MadMarx Have ever been to Spa? Triumph 4
H Any Two Seater BN4's Ever Produced? Austin Healey 8
bighealeysource Anyone ever remove windshield feet on 100-4 Austin Healey 3
CZ_Dave Ever gone picking? Other Cars 3
M TR2/3/3A Anybody ever dye wool carpet? TR3 Triumph 0
Moseso TR2/3/3A Quickest TR3 Tinkering Session Ever Triumph 1
bighealeysource Anyone ever mount a side exhaust on a BN1 or BN2 Austin Healey 16
6 Anyone ever mounted or seen Borrani wire rims? Triumph 6
D Cannot remember ever seeing this before Spotted 6
J How about the most enjoyable car you ever had? Spridgets 38
JPSmit Didja ever notice? Spridgets 9
Michael Oritt Did this ever happen to you? Racing 9
regularman Is it ever going to get summer? Spridgets 17
B Ever wonder why? Triumph 5
