TR2/3/3A Has anyone tried this new steering box top plate
Got_All_4
Check Mail
Compose Mail
Search
call us on +44 (0)1823 698437 or email info@revingtontr.com
HomeShopping Cart
Home » Suspension and steering » STEERING » TR2-3B WORM AND PEG STEERING BOX SYSTEM » TOP PLATE STEERING BOX TR2-3B RHD
Part No:
RTR3075RK
Price ex VAT:
£64.34
Price inc VAT:
£77.21
3 images
  • About This Part
  • Product Data Sheets
TR2-3B RHD Improved, spring loaded steering box top cover.
This cover incorporates a spring-loaded pin, which keeps the rocker pin firmly in contact with the scroll, thus removing unwanted 'slop' from the steering. This plate can also be used on some AC models for Left and Right hand drive, particularly Aceca and Ace
Customer Mr A Bond commented: I've recently (Dec2011) had fitted the top plate steering box cover conversion I purchased from Revington's. I decided the job was one for professional mechanics rather than me so I took it to a local TR specialists.They're good people but they'd not fitted one of these before and were dubious about the likely benefits. I'm delighted to say the conversion has transformed the steering on my car and equally pleased to say the mechanic who fitted the conversion - having driven the car before and after fitting - was equally impressed with the difference it has made. Thank you for
improving the quality of life when driving my TR3!
CJD
We have had at least a couple threads discussing the spring loaded top plate. I don't remember any consensus being reached, though. Several have used it and love it. Others have used it and don't like it. It likely has to do with how far worn your box is before you install it.
TR3driver
Great Pumpkin - R.I.P
I suspect there is more to it as well.
A friend of mine had it installed on his 3A, and it was so bad that I advised him (upon being asked) to take it back off. The problem is that the spring will compress if you try to actually corner hard; which gives even more play than the stock cover. You just don't notice, because you're turning against one side. So the play becomes more like lost motion; except then if you speed up or slow down, the spring moves and the steering changes without moving the wheel. Proper adjustment will likely minimize that (his was so bad that we could see the Pitman arm moving up and down during low speed parking lot maneuvers); but the bottom line is that the free play isn't gone, just hidden.
So IMO it also depends on whether feeling no play at all is more important to you than having the car actually go where you point it.
Even with the badly worn worm on my previous TR3A, I was never tempted. (Herman van den Akker used to sell them too; but quit.) Once you accept that it steers like a TR3 (rather than say, a Miata), the stock steering really isn't all that bad. Just different.
Got_All_4
Got_All_4
I don't mind the TR3 steering. I think mine is set up fairly well and I'm use to it and I know that I have to be in tune when driving it. That's part of the experience of having one. However at times going down the highway I since a bit of a drift is the best way to explain it. (hoping the part would fix this). Also the wife who doesn't enjoy the experience as much as we do is very anxious when she drives it. This year at the Roadster Factory Party I had just came off some medical problems and wanted her to be able to drive the car home if I for some reason I couldn't. She was scared to death on a test drive. She has driven it hundreds of miles in the past since I first restored it in 1982 when the steering was much worse. It's been 8 years since she drove it and I just did an update on the car for the last 4 years and the steering was part of that.
CJD
I set my boxes up tight. They have zero play at center, and feel rock steady at speed. The down side is the women in the house complain about the force needed to park the car. To me that’s a win win! Great driving car that doesn’t get taken to the mall every weekend. If I loosened it up it would bug me driving. I don’t even notice the hard parking at all.
Geo Hahn
...(Herman van den Akker used to sell them too; but quit.)...
I had one of Herman's and it seemed to help and work okay on what I think was a slightly worn box. But then it failed completely (possibly the spring broke, anyway the pin was stuck at the full-in position) and I was unable to get any support from Herman to find out how to disassemble the set-up or if they were prone to jamming.
Unfortunately the top cover itself is modified to make these so returning to original required procuring a new top cover.
mrv8q
I don't mind the TR3 steering. However at times going down the highway I since a bit of a drift is the best way to explain it. (hoping the part would fix this
I would make sure the silent blocs are in good shape!
Jim_Stevens
I can vouch for this improvement. I use a lot of RTR suspension parts and this was one of the first.
Got_All_4
Got_All_4
so carry the original cover in the trunk in case the new one jams. I'll put it in the same bag I have my points and condenser if my pertronixs fail.
Geo Hahn
Unfortunately for me, Herman required my original one as a core for the modification he would do -- otherwise yes, it would have been simple enough to swap it back on.
Looks like the Revington version at least lets you keep the original part.
Got_All_4
Got_All_4
I believe this is a bit different then Herman's. As I recall it was a bit taller and looked like a threaded rod coupler was welded to the top cover with a spring and a brass plunger that road on the top of the peg rocker shaft. If anyone has a pic of Herman's that would be great. Hear is a side view of the part.
Geo Hahn
...If anyone has a pic of Herman's that would be great...
Herman's may be similar, this is it:
The pin is now jammed fully in:
I could not get it to release. The top cover has an enlarged threaded hole for the spring-loaded adjustor, so I made a new (fixed) adjustor from a suitable bolt and jam nut.
TR3driver
What are the silent blocs?
It's a somewhat generic term today, originally a trade name for a method of bonding circular steel parts with a rubber filling. Also found in the rear shock links and the front eyes on the rear springs; but what he is talking about are the joints between the center link (the steering rod that runs the width of the car) and the idler and Pitman arms.
I would have to agree, I had a lot of trouble in the past with those joints breaking loose and contributing to loose steering. I eventually replaced mine with SS pins and solid brass bushings (from BFE). If I were to do it again today, I'd probably go for the (cheaper) Delrin bushings offered by Joe Alexander
https://www.the-vintage-racer.com/index.php/categoryhome/steering-and-suspension/product/69-tse-tr3
(Also available on eBay and through some of the usual vendors, I believe.)
With the brass, I added grease zerks so they could be lubed from time to time. Probably not needed (but certainly wouldn't hurt) with the Delrin, though.
Geo Hahn
FWIW - I used the Delrin from Moss. Made a huge difference in the stability of the steering. Not much bother to replace (i.e. not much to disassemble and the fittings came apart with the usual big screw separator from Harbor Freight).
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
M Side Curtain Rubber Has anyone tried MacGregor? Spridgets 2
angelfj1 Liquid Powder Coating - has anyone tried this? Restoration & Tools 4
MGBGT_noob MGB Has anyone ever tried this with an MGB? MG 10
mgblue79 Has anyone tried E85? Spridgets 16
W Home-made tonneau - has anyone tried? Triumph 15
B Has anyone tried this with their Healey? Austin Healey 9
J Has anyone tried The Amazing Roll Up Car Cover? Restoration & Tools 18
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
steveg Has anyone used a knock sensor? Austin Healey 0
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
G TR4/4A Anyone know if this car has sold yet? Triumph 0
Sherlock Spokane Race Track, has anyone been there? Racing 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
G Has anyone here had any dealings with ANGLO PARTS.COM ? Austin Healey 4
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
MY66AH Has anyone used this paint?? Spridgets 7
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
H Has anyone changed their electrical distribution? Austin Healey 7
regularman Has anyone here put a bugeye front end on a square Spridgets 2
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
60TR3A Has Anyone Undercoated Their Car? Triumph 27
scoutll Has anyone had a hardtop shipped? Spridgets 15
S Has anyone ever seen or heard of this? Austin Healey 9
T Advice, has anyone done this Triumph 2
jlaird Has anyone noticed Spridgets 20
NardisCNC Has anyone used the Oberg Engine Tilt Lift?? Spridgets 15
Cookie Has anyone changed wheel cylinders? Spridgets 20
bgbassplyr Has anyone else Other British Cars 9
L Has anyone ever had to.... Spridgets 12
gubba Has anyone here used this Rack & Pinion? Triumph 8
T TR6 Has anyone ever made a new TR6? Triumph 20
angelfj1 Octane Boosters - Has Anyone Mixed their Own? Restoration & Tools 5
S Has anyone seen....... British Motor Corp 1
weewillie has anyone Restoration & Tools 12
regularman Has anyone ever done any wind tunnel tests.. Spridgets 22
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
C Has anyone seen........ Triumph 6
healeyboz Has anyone.... Spridgets 5
jlaird Has anyone Spridgets 4
H Anyone Own or Has Driven a TVR Sagaris? TVR 11
AweMan Has anyone ever .............. Triumph 10
roofman Has anyone installed an electronic voltage ... Triumph 19
Nunyas has anyone else seen this? MG 14
J Has anyone converted to TBI? Triumph 11
neilh Has anyone successfully patched a leaking tank? Spridgets 15
