twas_brillig
I recollect reading in the past of folks using H-D mufflers on their Sprites/Midgets, but never any details as to how they were installed.
I've got a Bug-Eye, and traded some beer for two stock H-D mufflers a few years back: roughly 29 inches long by 4 inches in diameter.
I'm adding a header, which will require an increase in diameter for the pipe to the rear, and am thinking of going stainless as it will only require a couple of bends. I've got both a standard Spridget muffler (I'll replace the inlet stub pipe to match the new exhaust pipe if I use it) as well as the aforementioned H-D mufflers.
There might be enough room to clear the rear axle and transition to the H-D mufflers, but I'd sure appreciate hearing from some folks who've done this as to the size of the H-D mufflers they used and how they mounted them.
Thanks!
Thanks!
