T-Series Hardi Fuel Pump - Germany
PAUL161
How do they compare to an SU pump for operation and durability? PJ
Gosh, I miss Dave already.:blue:
NutmegCT
Paul - I've got my original SU and it works fine. Of course, the 60 year old MG has only 37K miles total!
A friend here recommends the SU solid state pumps, as well as Hardi and Ecco. From several user groups, they all have excellent reputations for reliability and "staying power".
Tom M.
Fitted a number of the solid-state SU units, including one for our personal MGB. So far there have been no issues with any of them.
PAUL161
PAUL161
Thanks guys, I was just comparing pumps for future reference. I have always used SU pumps, Dave D. converted the one on the 72 B to electronic and the pump on the TF is electronic also, no problem with either. Moss seems to be getting out of site on SU pumps, I found another supplier selling the same new SU pump 40 bucks cheaper. :encouragement: PJ
Stewart
I installed one in my gt as the SU pump no longer fit in the stock location after installing frontline's 5 link suspension. Works well and sounds almost like an su pump but the click is a bit deeper and more precise. One thing I ran into was a bit of fuel starvation during long pulls. Like the SU it's touchy about any leaks and like the SU it needs to be oriented correctly. Fixed the leak and it almost went away. The instructions that came with the pump did not mention the correct orientation which is the fuel outlet needs to be on the top if mounting horizontal. I had it upside down. Now that it's correctly mounted works perfectly.
Bob_Spidell Hardi Fuel Pump Austin Healey 39
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
FlyingCat Spitfire Fuel Sender Unit Triumph 2
G Twin HS4 Su's leaking fuel Spridgets 17
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
JPSmit Fuel tank sender - how does it work? Spridgets 4
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
RJS General TR Winter Blend Fuel Triumph 1
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
S Large capacity fuel tank Spridgets 1
D TR2/3/3A rearmost fuel line question Triumph 5
fpstude TR4/4A Fuel Pipes Connector Triumph 4
Healey Nut Fuel Sender Austin Healey 3
Cutrog1 Fuel Pump Ticking Austin Healey 13
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
D TR6 1972 TR-6 Fuel Vapor Recovery System Triumph 4
JPSmit Fuel line - gas tank question Restoration & Tools 5
R TR2/3/3A Fuel Gauge Triumph 19
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
S SU fuel pump servicing Austin Healey 4
steveg TR6 Source for fuel line P-clip Triumph 17
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
S Fuel gauge calibration procedure Austin Healey 18
M Fuel starvation Austin Healey 7
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
C MGA Fuel gauge question MG 7
vette A Quiet SU Fuel Pump Austin Healey 2
B Under bonnet fuel Austin Healey 15
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
J TR2/3/3A replace brake and fuel lines? Triumph 4
