TR3driver
Great Pumpkin - R.I.P
Re: Hard Steering? More pictures
Interesting. So the replacement joints have the splines clocked differently.<div class="ubbcode-block"><div class="ubbcode-header">Quote:] So I tried to center it as best I could [/QUOTE]Certainly the right way to do it, put the ball joint level and hold there while you tighten the nut. Come to think of it, that's probably what I did without ever noticing if the splines matched or not. But I only changed those joints once in over 200,000 miles, they don't seem to wear much since there is so little force on them. And the boots can be replaced separately.Don Elliott said:Randall - I tried the next spline over but it was still tight because now it was too far the other way.
