Hap, Doc, Tony, have you heard of this stuff?
PAUL161
Made by Valco
If so, is it any good? Says it's for engine reassembly. My concern is initial cam lobe protection.
Platinum
Never heard of it. That doesn't mean much, tho. I assemble with lith white grease if it is going in and being run soon. If it's gonna sit a while (white grease tends to 'solidify' if left for long) it gets put together with a 50/50 "slurry" of motor oil and STP...
I just KNOW Hap's gonna jump my case for that. :jester:
PAUL161
PAUL161
I use the STP method also. One thing I can't get through my head is, we built race engines out of the old flat head Fords back when I was a kid and they were hard lifters. We didn't have cam lobe break in problems and we were using high lift and long duration cams from Isky, Crane etc. Are the cams today of a poorer quality? We even increased the spring pressures to prevent float. Kinda puzzles me why these new cams are so delicate.
Platinum
I've had no issues with Crane, can't speak to what some others are supplying. I suspect we're seeing the same thing with cams and lifters as with other bits: third-world (lack of) Quality Control. If you lube the cam and use a good (zinc content) oil to do the run-in, there shouldn't be a problem... ~IF~ the parts are properly manufactured.
Which engine is this, Paul? A "spare" or going in right away?
tony barnhill
Great Pumpkin - R.I.P
Nope - I udse white lithium also except when stuffing oil pumps - then I use vaseline.
PAUL161
PAUL161
It's a 72 spare Doc. I want to build it back to new condition, with a slight exception of cylinder overbore. Then I'll probably "pickle it", and store it until I need it. Have a 77 engine to rebuild also. Something to do until I get another car to build. Don't know what that's going to be, I have a bunch of "B" parts, but would like a TF. Does Crane make MG cams?
R
RonMacPherson
I have a friend with considerable experience in aircooled Porsches. His shop also does Volvo and BMW's. He uses this on his cam train on his engine rebuilds...
He recommends it. The Valco lube.
Platinum
The cam in Herself's B is a mild Crane. I've fitted 'em to a number of customers engines, too. Haven't had to source one for a number of years but I'd bet they'll sell ya any grind you'd want.
This may provoke some discussion, but: Porsche is an exception I make with regard to valve-train prelube and sealants. I use "Porsche" materials and parts throughout. Assembly lube, sealants, gasket sets, everything. The customer is NOT coming back to me whining about this or that not being "correct". They pay the price, not me. The other is Ferrari. I have seen some sinful things... I will never be accused of taking "short-cuts" with those cars. *I* know it's a matter of perception in most cases, but too many "experts" lurk in the wings. :wink:
PAUL161
PAUL161
Thanks Doc for the info. While looking up Crane cams, I ran across this. Interesting, very interesting!
https://www.cranecams.com/pdf/Page175.pdf
Platinum
:wink: :thumbsup:
When it comes to lubes and oils and such like the cost, even for the most extortionate stuff, is trivial as part of the total cost.
Just rebuilt my Lotus 907 engine and I'm using the "factory" oil filter(£15) for the run-in, I could use a cheaper "equivalent": but it's not "worth" it for an engine that cost as much as this one did....
R
RonMacPherson
All his hard parts are from Porsche, or the aftermarket race shop in California, can't remember the name. His sealants are Permatex and Gaskacinch. His lubricants are his selection. Usually Castrol. His Cam lube is the Valco stuff. I asked him about it several years ago, when I first saw him using it on a 930 engine and he referred me to a site of comparisons. That hard drive has since gone to bye-bye land..
Just about every year he takes his vacation at one of the 12 hour races where he works in the Porsche pits... I give him credence..
Platinum
's all good, Ron. I don't doubt the Valco lube works just fine. I may likely try it on the next engine I rebuild for myself.
My issue wasn't with the variety or efficacy of the lubes, rather the perceptions of customers... if one walked into the shop as I was screwing his engine together, having all the Porsche labeled goo eliminates the "Twenty Questions" game.
"All Official. Nothin' but th' best for YOU, Sir." :smirk:
R
RonMacPherson
I agree, in principle. Sadly the German auto industry has a record of "upgrading" chemicals frequently.
Remember the 103 Benz motor with the front cover seal leaks. In two years Benz went through three different sealing compounds before they finally settled on "The Right Stuff". Just packaged in their container. Right after they switched to it, Benz did not have enough in the parts pipeline, our dsm told us to get it from the parts store. It was just "The Right Stuff", licensed to be repackaged by Benz...
Platinum
Yup. I'm about to glue an Alfa gearbox together with it! :wink:
PAUL161 Got My HIFs Back from Hap. You were right Doc! MG 4
T Articles by Hap Waldrop reg engine disassembly and assembly Spridgets 1
BlueMax "Thanks Hap" Spridgets 5
Mickey Richaud MGB Thanks, Hap! MG 5
PAUL161 Carb rebuilder? Hap? MG 5
PAUL161 Question for Hap and Others. 140 hp XPEG? MG 1
Basil Happy Birthday Hap! MG 8
I How do I get a hold of Hap? Spridgets 2
Hap Waldrop Hap will be on track sooner than thought :] Racing 19
Scott_Hower Hap started my head... Yay! Spridgets 13
bugedd VTO wheel fit issues, help Hap! Spridgets 24
B Where's Hap? Spridgets 12
G Hey Hap, got $25 ??? Spridgets 16
PAUL161 Hap-- Exhaust manifold/header paint? MG 2
PAUL161 Hap, Crane cams? MG 6
jmwuva05 Another one of Hap's masterpieces Spridgets 4
T Hap - some TR guys need rims from you Spridgets 1
T Hap - 175/70/13 or 185/70/13 for your Superlights? Spridgets 26
jmwuva05 Hap and my engine Spridgets 5
mccalebr Hap's engine build log Spridgets 7
DrEntropy For Hap and th' Day: MG 9
mccalebr Eye candy - Hap's HS2 carbs Spridgets 20
M 1275 Engine Rebuild - Especially Hap! Spridgets 11
mccalebr Hap's 1275 engine builds for Ray and Drew Spridgets 15
T Hap, what is that thing...? MG 14
B Thanks Hap! Spridgets 3
jlaird Hap, I need help Spridgets 0
64rocksprite 12G295 question...Hap?? Spridgets 4
healeyboz New seats and Hap's Carbs Spridgets 14
jlaird Morning Hap Spridgets 0
jlaird Hap Spridgets 2
AngliaGT How Cool Is This?- For Doc Lotus 4
aeronca65t Doc Weiss-Berwick, PA Racing 0
JPSmit Hey Doc!!! Other British Cars 3
AngliaGT Doc - Here's One for You Other British Cars 3
AngliaGT Hey Doc - Did You See This Cortina? Other British Cars 1
DNK Hey Doc Lotus 1
HEALEYJAG Doc's Jags bankruptcy Jaguar 2
Mickey Richaud Doc? Other British Cars 7
Mickey Richaud Hey, Doc and Mark II Other Cars 5
JPSmit Hey Doc & Mark Other Cars 16
PAUL161 MGA Doc, Do You Know MGAs final gear ratio? MG 11
S One for Doc...... Lotus 5
T Doc or Brad Pitt? MG 9
T Doc made me do it.... MG 28
NutmegCT One for Doc Other Cars 30
T To Kerry and Doc....Thank You! A little Progress Other Cars 3
S Doc, ya gotta be EXTRA good this X-mas!! Other Cars 11
Steve One for the Doc and other Alfisti Other Cars 2
weewillie HEY DOC here's a benz for you Other Cars 9
