Because the max transceiver power for unlicensed walkie talkies in SA is 1/2 watt from what I can gather. I would rather get something with a little more power.
Surely I can order on Amazon or Takealot (SA equivalent to Amazon) but the radios would conform to the SA standards. 1/2 watt (unlicensed) is for the Boy Scouts
Trade Kite Baofeng BF-888S 16-Channel UHF Walkie Talkie (2-Piece) | 400–470MHz Two-Way Radio | Long Range Up to 8km | Rechargeable | Noise Reduction | Black : Amazon.co.za: Electronics
Thanks JP! There are some issues with this model and the seller but I will look for other models on Amazon.za.
This particular model requires a special to Baofeng cable in order to program using CHIRP, I intend to buy one to use right out of the box.
Also, if it's sold in SA the charger is probably 230v which would render it unable to charge when I get back home.
The seller only has a 41% rating and for me I wouldn't buy from a seller with a low rating like that.
But, I do intend to look for other models that I can purchase. Thanks!
So this is what I finally ended up getting. You can select between 2 watts and 0.5 watts stations. It has lots of features like CTCSS and DCS codes for some privacy and host of others. It even has a built in FM receiver.
It's not a GMRS radio (which is 5 watts) but to be "legal" these radios will do the trick.
