Rob Glasgow
Hi Guest!
www.classiccarperformance.com
I think the problem you're having with LEDs is the projector housing in the Jag. If the diodes are not lined up in the focal plane, they won't illuminate correctly. I'm guessing here because the halogens you selected are designed for projectors.LED bulbs are not quite there yet, I put a set of four LED conversion bulbs in My Jaguar XF.
I have to admit they are a much whiter light not yellowy like a halogen bulb, but they do not seem to carry as far,
I just chose those as an example, of what was available for brighter whiter lights as opposed to standard halogen.I think the problem you're having with LEDs is the projector housing in the Jag. If the diodes are not lined up in the focal plane, they won't illuminate correctly. I'm guessing here because the halogens you selected are designed for projectors.
In 2022-23, it's probably closer to 98%.Considering in 2019, 86% of cars sold came with LED headlights, I would disagree with that article.
Try fitting one in 50 year old car.Considering in 2019, 86% of cars sold came with LED headlights, I would disagree with that article.
I can not vouch for the headlights but i have seen the copy smiths gauges which are produced in India and they are very close to the original.Good discussion here but I am looking to preserve the look of OEM headlights. That why I ask I’d anyone had tried these units from India. At least on the surface they appear to be marked Lucas. I know there are better modern versions of lights out there just as there are much more powerful and efficient engines to replace my old six cylinder. But that’s not what I’m shooting for. I ordered a set of these lights and will report back on my impressions. My goal is pretty meager. They need to look like something that came on the car when new, and they need to produce at least as much light as the original incandescent bulbs. Any improvement beyond that is a plus.
What year is your XF? The second link you posted was for a A4 Audi.Try fitting one in 50 year old car.
the discussion was about halogen/ LED replacements. In old British cars. They just not good enough yet.
Like i said in an earlier post, I just posted a link to show what was available as an alternative to standard halogen.What year is your XF? The second link you posted was for a A4 Audi.
The Holley RetroBrights Joe posted look promising because it seems the reflector is designed for an LED bulb.
