Trevor Jessie
Re: ...IT's HOME!!!
Jack, I didn't want you to help him... just give commentary. :wink:
Yesjlaird said:Do you have the harness for the dimmer switch?
Yep...same here...then it runs out to the center of the car behind the radiator (or, in front of it) where the lights hook up to it from both sides.....just gotta figure out how to hold it up against the body.Trevor Jessie said:Dunno about a '63, but on my '70 midget the harness passes through the nose cone splash panel on the passenger side.
Yep, just gotta find some big enough to take the harness.....don't know what I did with the originals.Trevor Jessie said:Z-clips along front flange behind the grill.
jlaird said:Tony, you will play heck setting the engine with both the mounrs bolted in. Bolt in the drivers side one and bolt the other to the motor mount on the other side. Bolt the drivers side mount to the engine as well.
Now it will preaty well set in when you are ready.
