UmmYeahOk
1st question is the choke cable. Here's what I got:
My choke cable splits off into two from the interior knob. I assumed its supposed to look like this:
But it seems as though every other pic I find has their installed like mine. Long cable connected, short cable dangling. The short cable is actually too short to be attached to the carbs. Its long enough to be attached to the heater control valve though, which looks correct, but then what would the heater knob control? But the installed cable does look a bit too long. This cant be right.
Other question is the speedometer cable. Here's what mine looks like:
Others I have seen do the same, only looped over the engine/transmission, but I worry about it bothering the throttle arm. The cable is also INCREDIBLY long. Which makes me wonder if its actually supposed to loop around the whole engine ducking under the oil pan. As there is too much cable length when installed the other ways.
