go to an automotive paint store they shoud have attachment pushon thingamabobs that will hold it to your grill . A hardware store may have a spring nut that will push on and lock.
I'd make a joke about that also being the nickname of a certain frequent poster, but as the Moderator it's probably better if I set a good example and avoid such juvenile pranks.
All Classic Mustangs use an attachment device called an Emblem Nut or "barrell nut".
This device pushes into a drilled hole in sheet metal and expands and grips the smooth emblem post when it is pushed in. These nuts to not require a lot of "real estate" on the backside of the fender, etc, and may be perfect for attaching your emblem to your grille.
