Stanpart # 102689. $3.50 at Spitbits (Spitfire is same as TR), $7.99 at a major Pennsylvania supplier (yikes!), $3.89 from Canley Classics in the UK, and (as part number 661-430) $6.95 from Moss Motors.
I've obtained them in the HELP! section of the flaps though of course those lack the (poorly) threaded hole in the center and are unpainted.
I actually prefer the tyoe with the hole though I JBWeld a nut in there to back up the hole else it may strip out before the cap comes loose. I carry a 2" eyebolt of the correct thread that I thread in (by hand) until it contacts the hub, wiggle a bit, thread some more etc as the cap moves out.
The nut works slick, thanks Geo. One comment, though, if you use a plated nut it's proabably best to roughen up the surface a bit. On my first attempt, the JB Weld didn't adhere to the nut and it fell out inside the cap. Had to use a big 1/4" lag bolt to remove the cap, since of course the threads in the hole are worthless.
PS, I also cut a much shorter screw, to leave in the hole and seal it. Don't like leaving it open for dust & dirt to get into the bearing.
