GPM requirement for a replacement pump
Required fuel flow at maximum horsepower is:
The brake Specific fuel consumption of an engine ranges from 0.35 to 0.6 lb/hr/hp. Average is about 0.5 lb/hr/hp.
Gasoline weighs 5.6 to 6.5 lb per gallon. Use 6.0.
Example: 150 hp engine, .5 lb/hr * 150 hp = 75 lb/hr.
75 lb/hr/6 lb/gal = 12.5 gal/hour = 0.21 gal/minute = 1.7 pints/minute.
Example: 100 hp engine, .5 lb * 100 hp = 50 lb/hr
50 lb/6 lb/gal = 8.3 gal/hour = 0.14 gal/minute = 1.12 pints/minute.
A Pump rated at 8.3 gal/hr or more would be required for 100 hp sustained output. 12.5 gal/hour for 150 hp.
As a general rule, a pint a minute. With pressure not to exceed 4PSI.
Those were the two most opposite style replies I have ever seen. I love it. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Not quite Steve, I would say they're in agreement /bcforum/images/%%GRAEMLIN_URL%%/grin.gif Dave went into the mathematical detail to derive his flow rate...
Dave Russell said:
Required fuel flow at maximum horsepower is:<snip> sorry Dave it's a bit much for a quote /bcforum/images/%%GRAEMLIN_URL%%/wink.gif </snip>
1.12Pints/minute...
Doc gave the "rule of thumbs" with his answer and added on top of that a pressure that should not be exceded /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
They're in perfect agreement I would say /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
well durn it all. MAYBE I need to read a LITTLE closer next time. Especially since Steve was talking about the STYLE of reply, and not the answers... *smacks forehead*
Didn't see Dave's physics lesson 'til jus' now. He musta hit "Submit" at 6:41:56 and I at 6:42:03...
My reply was as general as Keith's question; For all I know it was a quiery into gas station pumps./bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Had it not been th' MG forum of BCF, my immediate response woulda been: "Some!"
/bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
The easy answer is to look at the specifications of the original fuel pump that came in the MGB. For the AUA 150 pumps used on the early (up to mid 64) MGB is 1.1 Pints per minute, for all the later MGBs using the AUF 300/AZX 1300 series pumps it is 2.4 pints per minute. Note, if you look at the Burlen Fuel Systems web sites, the specifications for volume will be slightly different as they are given in Impeiral pints or gallons.
Looking at Dave's figures, it can be seen that the pumps used in the early MGBs was barely adequate and is probably the reason forthe switch to the later pumps (besides the better flow smoothing features of the later pumps.
Cheers,
