G
Nice color Shawn. Goes well with TR6 styling. I am working on a windscreen idea but plan to weld a frame to the roll bar and screw in safety glass. Waiting for a price guesstimate from the glass shop. Enclosed a few pics of my setup. Just finished the Delco-style alternator conversion. I took out the airbox and went with K&N filters. You can't see it but the bonnet has 13 louvers sitting right atop the air filters. I smoke-tested the setup and found that plenty air gets sucked in at speed. And at idle, plenty heat from the stainless headers has a little more chance to escape. Wanted to show you the custom tips on my Falcon Sport duals. I rigid-mounted the whole setup with custom bracing and installed 2 12" triple walled flex pipes to absorb the shake. Went with 2" stainless band clamps to avoid crimping the whole system. Works well as I have already pulled it down once, only used a rubber hammer a little. You are right, the "braaattt" noise that only a TR6 will make is priceless. I can't keep up with a mustang but I sound like I can.
