poolboy
I'm betting you guys have already discussed this but I'd like to know a little more about it.
My 74 is stock and I have the original valve cover vented to the carbs in the standard manner. I know that the carbs are drawing oil vapors from the cover,but I don't have any ill effects. The plugs don't show any thing unusual as far as deposits or color. No smoke from exhaust even though I believe I have 97k on the engine. Compression is nothing to write home about with an average of 133 dry and 139 wet.
Yet my oil consumption is about 1 qt./ 500 miles of conservative driving; more if I race around the back roads.
Ok. here's the Question. Do you think the installation of the oil seperator would make much of a difference in that oil consumption. I know some is going past the rings but by all indications that I mentioned previously I think a large percentage is being sucked up by the carbs and burned in the fuel mix? Oh yeah the leaks. Only the rear main, believe it or not!
