YankeeTR
PeterK said:The AC Hydraulic DK20 is the only jack I would recommend, period. I bought one after the 3-ton Chinese jack I was using suddenly released as I was lowering my Audi and dented my rocker panel. Not safe!
The DK20 has a D-handle incorporating a dead man's valve. To lower the jack you turn the handle to the right and hold; if you let go, the jack stops at the current position. It is very smooth, controllable and safe. No worry about tightly gripping a tube handle and trying to release the jack to lower it just a little, without the jack going down further than you intended.
Made in Denmark, not China!
Bought mine here (also bought my 4-post Bend-Pak lift here too):
https://www.asedeals.com/hydraulicjacks2.html
AC makes really nice equipment. I used to hang around another site that had an 'authorized' AC dealer on the tool forum. A few years ago he said AC had abaondoned the US market...thanks for the link!
My 19 year old Sears 2 ton floor jack (Japan) still works good...but a new AC would be nice!
Regarding lifts...I bought my two-post used about ten years ago. It's now probably 25 years old. A 9000K unit, it's built like a rock and should be around long after I assume room temperature...best $1800.00 I ever spent...
I'd put off an engine re-do, paint job, restoration or just about anything to have enuff $$$ for a lift...
