Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
Wish I had some sage advice for you, Jack, but I'll leave that to smarter folks. I do agree with Kim -- maybe it's time to sit back with a fine beverage of your choice and think it through.
Nop, is not air. when you look up inside the clutch area through the view port you can see the thorwout bearing trying to work but it will not go all the way in, but it wants to.
It does not even compress the springs in the pressure plate as something is preventing it, ie the center part is on backwards I am sure and prevents proper movement.
We will see. Now I have become intense on these problems and will know the reason why. I was sure I put the part that said "towards flywheel" that direction but do not remember checking if the long side was away from same.
