bash
Okay, some of you may remember that a while ago I was on this board asking whether you thought it was feasible for me to restore a TR6. I read it all withgreat care and somehow managed to ignore all of the parts that warned of huge expense and misery, and focused on the parts where people said it was going to be great! Anyway, as a result of much looking at ebay auctions and various club websites, I am going to look at a car this Friday. I am hoping that you experienced people will help out a newbie with some advice of what to look for. The car I am looking at has been sitting (indoors) for a few years, and so I would have thought that trying to start it right away would be a bad idea. The seller said that it was running "a bit rough" when he put it away and he hasn't started it since. What can I do to check it out without turning the engine? I know about checking the thrust washers, but what else can I look at?
From the pictures I have seen, the only worrying rust (I know, I should worry about all of the rust...) is a line where the inner and outer wings meet (basically right below the side of the hood, inside the engine bay). Is this likely to be the visible part of something much worse? Is this a reasonably straightforward repair?
Given that the car has been sitting for a few years, what am I likely to need to do to get it back into running condition? Obviously I would change all of the fluids and apply lots of grease to the relevant areas, but I am guessing that the carbs need a clean, and I would probably fit new diaphragms, etc. Am I likely to need to replace the brakes, or would a clean up do the job? Will I be looking at rebuilding the calipers with new seals etc? How about the hydraulic cylinders?
Sorry to go on like this. I am very excited to be getting close to owning the car I wanted as a child! I just don't want to rush in and buy a car that will never be back on the road. Any other advice you can offer would be greatfully received!
