Girling Brake Fluid Reservoirs Leaking
Fat Cat
Hi all
Does anyone have a tip on where to get decent Girling brake fluid reservoirs for my BN7?
The ones I've ordered online keep leaking and destroying my paint. (Tried the "no leak" seals already).
It seems that most online vendors sell the same poor quality rebuilds.
Due to an upgraded two-circuit brake system I would require:
  • 1x reservoir-can with dual outlet for both brake and clutch
  • 1x reservoir with single outlet for the second brake circuit
Any feedback on where to get matching high quality reservoirs that look original and definitely don't leak is highly appreciated! :smile:
Thank you very much & best regards,
Fat Cat
PAUL161
Possibly Summit Racing. They have quite a few. PJ
steveg
It's not about the reservoirs, it's about the seals. IIRC I'm using the Stat-o-seals from Pegasus, which are aluminum with a viton center. This is with DOT5.
I would call a reputable outfit like Pegasus and ask them what they recommend.
Edit: the Stat-o-seals may be iffy for non-silicone standard brake fluids. Most on the net seem to be using copper washers.
Also check the flares on the supply pipes. I ran the stainless pipes for a while and they would work-harden after a couple of tightenings and start to leak.
F
Fat Cat
Hi Steve, thanks for your reply. My reservoirs are actually not leaking at the bottom / connectors but rather splashing on the top end at the lids. Either the fluid comes through the breather-hole or through the thread of the lid. I've tried other seals already. Reached out to pegasus as recommended.
GregW
Platinum
Have you tried the "no splash" seal that Moss sells? Part #582-505
Keoke
Maybe u can wrap the threads with Plumber Teflon tape. ???
I have one in my BN2's reservoir--it works. But, how high are you filling your reservoir? Brake fluid gets hot, and hot fluids expand; I fill my reservoirs to just below the top of the cylindrical part of the reservoir or, for the BJ8 I fill to the top of the clutch cylinder (easier to tell if anything is leaking). Like radiators without recovery systems the system will find its own level.
Edit: I think these can be found--it's somewhat of a standard size--in the 'HELP' section of parts houses, possibly at a lower cost, or :
CraigC
Although that may seem like a good idea, there is no place for Teflon tape anywhere in an automotive brake system. One little bit of that tears off during install and it will find its way into a critical orifice with potentially dangerous consequences. Along the same lines, never use it in a fuel system either.
Teflon tape is intended to be used on tapered pipe thread connections. There are none of these in the Healey fuel and brake systems.
Keoke
OH MY Goodness!
This fellah ain't neva done no real plumbin ifin he did he would know little pieces of teflon tape do not come off even when joint is retightened>
CraigC
OH MY Goodness!
You don't know just how wrong you are with that comment my friend. 40+ years in the automotive repair world. I have fixed more vehicles than I can count that had Teflon tape applied in improper locations, primarily fuel systems, that resulted in failures.
Keoke
I werent talkin bout no vehicle we talkin bout plumbin and their Teflon tape it be tough man!.
vette
Fat Cat, I’ve had a similar problem but not very severe. I have what I believe is a very good reservoir bought from Healey Surgeons in Maryland, but the cap is so tight on the threads that it doesn’t thread down far enough to compress the gasket enough and the fluid can squeeze past it. It is not much, but it is enough to see some around the top edge. Also, on very long drives, I have been able to get my fingers wet if I put them at the bottom of the can, but I know it is not the tubing fittings at the bottom because the flare nuts and tubing are never wet. The can sides will show some wetness so I know it is coming out the top. I use silicone fluid so it doesn’t even damage the paint on the can, and the weeping is so minor that the level of fluid in the can does not seem to go down. Yet the can is wet. In my case I blame the cap.
I was going to change to more modern plastic reservoirs. I bought a dual reservoir plastic set up from Summit Racing. It uses rubber hose to connect to the copper tubing. It would fit well, but because my problem is minor I never installed it. It would be clean and leak free.
You could lower the level of fluid in your reservoir to see if that helps. Remember the standing fluid above the master cylinders is the whole tubing and the can, so you really don’t need much in the can.
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
BOBBYR Girling brake booster Austin Healey 5
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
T Lucas girling brake pads Triumph 2
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
rr64 Wanted: Girling Brake Line Banjos Other British Cars 9
F girling master cylinder [brake] Austin Healey 3
A Wanted Girling Axle for TR2 Triumph Classifieds 5
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
R TR2/3/3A Girling Rear Brakes Triumph 9
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
S T-Series girling shocks MG 0
R Girling vs other wheel cylinders Austin Healey 10
2 TR2/3/3A Girling axle disassembly for shipment Triumph 6
H Problems with Girling master cylinder Austin Healey 8
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K The Girling Company? Triumph 5
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
HerronScott Lucas and Girling Triumph 3
H Rebuilding Girling 16P Triumph 5
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
P Girling brakes on a Chrysler? Other British Cars 8
Z Girling/Armstrong lever arm shocks Spridgets 2
