TR2/3/3A Girling 10" Rear Brakes question
Jerry
Nice picture, I will go back and check mine to be sure the springs are on correct. By the way those MOSS shoes I bought were REAL tight to get the drum on. I had to do some adjusting.
Jerry
TR3driver
Great Pumpkin - R.I.P
A common complaint. Back in the bad old days, the new friction material would be ground down to just match your drums, but almost no one does that any more. A shame too, as I recall it made a big difference in my first car (full size Chevy with front drum brakes & no power assist).
TR4nut
TR4nut
I used an old belt from a belt sander, just cut it and used the long wide sandpaper surface to sand down the shoes once they were in place. Fiddly operation but didn't take too much effort as they were pretty close to the correct size.
Aradford46
I'm in the process of rebuilding a Girling 10" brake and find I am missing the steady posts. Does anyone know of a source for these or even a rough drawing and I could make them maybe.
TR3driver
I've got some somewhere. If no one else chimes in by tomorrow, I'll start hunting for them. Don't really want to let them go, but at least I can get detailed measurements for you.
From memory:
The thread is British, but I don't recall offhand if it's BA or BSF (or BSW). They're about 3/4" long (but 1" would work OK). Screwdriver slot on the outside end, inside end is turned down to minor diameter of the thread (ie smooth) for perhaps 3/16". Should be a felt collar that goes on there too. TRF claims they have the felt, under P/N 7H4429
PS, Welcome to the asylum. One tip: It's usually better to start a new thread with a new question, even when it's related to the original question. Usually, you'll get more responses that way.
PPS, Perhaps I'm mistaken about the British threads. TRF says that a JN2108 will work for the jam nut, but JN2108 is 5/16 UNF. I still don't think that is correct, but it has been a long time since I had to fiddle with those dang posts.
TRopic6
Aloha A-46,
I dismantled an early 3A axle to get diff gears & 10' brake parts for my '59 stored in SC. I disassembled the back plates to sandblast and managed to keep the posts aside in a place I could get to them. Here are a few shots; pretty much as Randall remembers. Threads are regular 5/16 UNF; I ran a regular nut down the threads no problem. Maybe you could mill one out of an old bolt.
Jeff
sp53
yeh my 10 inch are like Randall’s picture, and if I remember correctly the springs have to go that way or the full spring will rub on the wheel cylinder rubber. I am also pretty sure those are 9 inch in the picture or they hobbled 10 and 9 together.
TRopic6
I measured them all and they range from 1.228 & 1.248. Maybe they started life at 1 1/4" and wore down in service.
Jeff
TR3driver
Could be! On the TR3A I had back in 1977, those pins were so out of adjustment that I would hear a mysterious "clunk" shortly after releasing the brake pedal. The shoes would walk out to match the drum when the brakes were applied, then snap back when they released. I can't prove it was wear, but it seems the most likely explanation. There was visible wear on the shoes as well.
R TR2/3/3A Girling Rear Brakes Triumph 9
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
A Wanted Girling Axle for TR2 Triumph Classifieds 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
S T-Series girling shocks MG 0
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
R Girling vs other wheel cylinders Austin Healey 10
2 TR2/3/3A Girling axle disassembly for shipment Triumph 6
H Problems with Girling master cylinder Austin Healey 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K The Girling Company? Triumph 5
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
HerronScott Lucas and Girling Triumph 3
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
H Rebuilding Girling 16P Triumph 5
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
BOBBYR Girling brake booster Austin Healey 5
P Girling brakes on a Chrysler? Other British Cars 8
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
Z Girling/Armstrong lever arm shocks Spridgets 2
T Lucas girling brake pads Triumph 2
davelgee Girling MK2a vacuum servos? Other Cars 31
Scott_Hower Girling Red Rubber Grease? MG 1
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
