My gen light comes on at under 800 RPM idle so thinking of the converted generator to alternator as I too will drive it to death.
What did it cost to have done in Portland?
Except that he's having a run-on problem.Car tachs usually read low so perhaps increasing the idle speed on your tach to 1000 RPM may resolve the problem.
The shop I went to actually had a universal mounting bracket that will work, I did have to add 2 bolts so bracket 35.27$ Napa 55 amp alternator and a connector plug 77.80$. I ended with the items in this tech note from hereWhat is the off the shelf solution including the mounting bracket?
I took an old bad regulator and did this to it to make it work. My car is negative ground and i use an alternator.Well after comparing the 2 diagrams for hours , Daves shows brn/yel (alt output) powering all 4 brn wires. Don't I have that with the wire from the bat. term on the alt. to the solenoid? The brn from the sol. should feed the other 3 brn wires at the RB340. The plug at the alt has a red pigtail and a white pigtail, right now the red goes to the batt. term on the alt. The white connects to the brn/yel if the white wire is an output, that should work the dash light. I just need to figure out where the cut-out contact is and block it.
