Tom and Don,
This is what I found. There is no guarantee that it is correct as I did take the carburettors apart about 15 years ago to rebuild them. You can see what 15 years worth of dirt looks like!
As you will see the jet lever arm is in the middle of the fork, and this is what it is like for the rear carburettor too. Also the connecting rod is in the middle hole on the cam.
I did a little experimenting while I was there as I thought that the cam didn't push the throttle open very far for the fast idle. It only moves the adjuster up about a millimetre. However once the engine is warmed up if I move the throttle that amount it increases the revs quite considerably.
You will see that my wiring harness has also suffered in the past from the end of the choke cable.
I must get around to cleaning up the engine compartment!
(Incidentally Tom, while I was playing around with the choke and throttle I noticed that the ammeter showed about 5 amps with the idle speed at about 1,000 rpm, when I raised this to 1,500 the ammeter needle flicked about between 0 and +30, but beyond 1,500 it showed 5 amps again. Maybe this is a design characteristic!)
