TOC said:I did make a call this morning, and asked, but the person did not know 1500 transmissions, which, he said, are different.
Thank you for your effort though!
Hi Guest!
TOC said:Oh, and which way did the knob move on acceleration?
Deceleration?
TOC said:Okay! That means the ring on the synchro is moving aft, engaging third deeper.
Usually NOT a sign of angle-worn synchro engagement teeth.
That means, third gear, but it doesn't move.
Still apart?
When you pulled the cover, were you in neutral?
If in neutral, hold the clutch in to free up the input shaft, roll third gear by hand (going to be hard....you'll be spinning all the gears AND the clutch disc) and see if while rolling third gear you can get it to move fore and aft any.
There are select-fit shims on the aft end of third gear.
Transmissions can be funny, but they are prety straightforward.
TOC said:Well, since the trans is out of the car.......I would ask you to shift it to third, but without the shift forks doing it, I think the ring might go too far and the springs and balls might pop out, so we won't do that.
If you could carefully do that, and watch the balls, then turn the input with a drag on the output, and see what moves in both directions of input rotation (reverse would simulate deceleration load).
TOC said:Alright, then it's more tork than we can generate by hand creating it.
Now, one other thing.....I have had movement of shirters in some cars, usually second gear, as that's usually the "torque" gear, and it' engine movement in rubber mounts, sometimes fore and aft.
This wasn't the entire shift lever moving, was it, but rather pivoting?
Has to be third gear shims.
Have you tried feeler gauges at the back of third gear on the mainshaft to see how much clearance you have there?
TOC said:Whatever it says in your Factory Shop Manual for the spec at that point, which is set with shims (select fit).
.086 ain't a lot, but figure the mechanical advantage of the gearshift lever. How far from the centerline of the mainshaft to the gearshift pivot (vertically), and how far from the pivot to the knob?
If 3:1, that's 1/4" at the knob.
What surprises me is you cannot get the gear to move on the mainshaft by hand that much. You should feel the gear "clunk" when you slide it fore and aft.
And, conversely, second gear (other side of the select fit shims) should move the same, and you should have had the same movement in the shifter.
TOC said:#16 is the select-fit shims, 59 is third, 57 is second.
I think.
Unless #16 is a split between 2nd and 3rd, in which case 16 is the 2nd and 3rd gear bushes.
That would make 58 the shims. Hard to tell from the size of the drawing.
What does your FM say the clearance should be?
