1500 midget
In 3rd gear I notice that the gear shift stick will move a bit when I press the gas pedal (and then move back a bit when I let off of the gas). I did remove the stick shroud and didn't notice an equivalent movement of the transmision housing movement (I looks like the majority of the movement is in the stick).
Any ideas on what is causing this and should I be concerned?
My first idea is that since it doesn't do it in the other gears it is a sign of some wear/slop in the 3rd gear causing the gear shift stick to move.
Hi Guest!
