davidk
For quite a while, the gear shift lever will vibrate. It does it more as speed increases, right before a shift. If you hold your hand against it, it stops most of the noise from the vibration. It doesn't do it in 4th. I've had the car up in the air and checked the drivetrain and nothing appears to be loose or have much movement (u-joints). Any ideas? Thanks as always.
